Antigravity Batteries Product Giveaways - ENTER NOW! Read more... ×
HELP? Advice on 302cc big bore stroker (82x57.2)
Does anyone have experience with this 302cc mod?
82mm piston, and 57.2mm Hot Rods crank. (Stock is 78 x 52.5mm and 12.9:1 compression)
I'm looking for more low-end grunt for trailwork, occasional enduros. I have an 270X kit (Athena), which is fantastic mod for low end grunt.
270 = good!
302 is probably better, but do you have it, and do you like it?
Edited by WA_trail_rider
If your talking about the max rpm kit with the ice cube cylinder its fricking awesome.
If your building your own i dont know.
Big difference is the max kit uses a longer rod, stroked oem honda crank and a taller deck which requires modifying your upper engine mounts.
case mods are needed to fit the crank.
Hi Shovle65, thanks for your reply. Are you riding one of these now?
I was planning to use HotRods 57.2mm stroker crank and any of the 82mm piston kits. Prefer not to do case mods, I'd only do it if it was simply exchanging parts.
Thanks for warnings about upper deck, case mods, engine mounts. This looks like more hassle than I want...
Found a useful thread:
http://www.thumpertalk.com/forum/showthread.php?t=954076
Anyone else have done this 297cc or 302 on the 250X?
Yes. Im riding and racing one of these now.
Only racing enduros though.
Main reason for the 302 conversion was i was begining to hate the wide ratio transmission due to my riding style. Needed the bike to lug better and the stroker crank has definitely fixed that.
I dont know much about the hot rod cranks but when i researched the mod noticed max rpm didnt offer the kit with anything other than a OEM honda crank due to strenth. (according to them) Plus all there kits with hot rod cranks were a lot cheaper.
Seems that the longer rod was needed also do to added stress on the crank which required the taller cylinder and longer studs.
The cylinder used increased the cooling capacity as well.
Case mods are minor enough to return the bike to a 250 with no problems.
I assembled the motor and had the case mods done myself.
http://www.maxrpms.net/shop/index.php/motorcycle-kits/mk-honda/crf250.html
PS. the stock x clutch cant handle much more than stock. You will need to convert to a r clutch pack without the judder spring at the minium.
the x crank and the r crank are differnent in weight and stator used.
I would have just got a new bike but it seems that no one make a bike like this so far. Maybe in a few years. :thumbsup:
Was hoping that the new KTM 350XC would lug better but from what ive heard so far it doesn't.
  • Similar Content
    • By Hayden Ploeger
      So I have never actually posted on one if these forums. I usually just stalk them to get answers but I messed up and I might be out 800 bucks🙃
      I have a 2013 CRF250L that I recently bought and I wanted to get supermoto wheels for it. I got online and almost ordered a set of warp 9 wheels but then I saw an add on Craigslist. Long story short I purchased lightly used warp9 wheels from a 2012 CRF250X not realizing the axles are different sizes. The rims are the same size as what comes in the kit from warp 9 but the spacers and bearings are larger on the wheels that I got. Does anyone know if I can buy new bearing and spacer kits to go in these hubs to fit them on my bike or will I need to purchase new hubs entirely?
      I work on a fishing boat and I'm off the coast of Oregon for a few weeks and wanted to order something so I can get these wheels on my bike when I get home.
      Thanks,
      The guy who f***** up
    • By yrun
      I have a new 16 crf250x.  Would like gear it up a bit for two track, orv trails.  How much can i drop the rear sprocket size without shortening the chain.
      Thanks men!
      Joe
    • By yrun
      I was working on installing new needle for JD jet kit today. While trying to get a bit more rotation on the carb i broke a little plastic tee on the top of carb (left side). I think its some sort of vent? Not sure if the brass part is threaded into carb or not? At any rate it will have to be replaced. Wonder where i'd get this little item?
      Any ideas?
      Thanks joe
    • By ronbuell
      Ever been bored or really ticked off by not being able to reach your fuel screw for trailside adjustments?  Well, I decided to do something about it, and not spend a bunch of money to boot!
      Parts liste included:
      Short length of brass tube. Short piece of old, broken speedometer inner cable. Nut from the rejects bin.   I welded the nut to the speedometer cable inner and soldered the other end to the fuel screw using the brass tube as a connector.  I didn't need or fab up a holder for the end, but I wouldn't be too hard. My DIY flexible fuel mixture screw works great and the price is right! I highly recommend this mod.
      Cheap, but effective DIY fuel mixture screw
    • By Frana
      Hi everyone. I’m new here so I don’t really know what to do but let me explain what’s up, so I bought this 2008 CRF250X today and everything looked in tip top shape, but within a few minutes of riding the engine and radiator gets to hot to touch and then the bike dies at low RPM, then it is a hassle to get it started(i drained the battery trying) and once it fires it dies super easily again like by touching the trottle or just idling and I have to be super cautious on the throttle to grt it going. I don’t know if it is overheating or if there is another problem, if anyone could help me it would be very much appreciated.
