08 450 EXC Boiling over
So I replaced the radiator fluid on my 08 KTM 450 Exc...
I refilled it with 1 L of Engine Ice... I noticed on my skidplate there is left over coolant after I run the bike and take the skid plate off. The coolant was traced up the frame to the overflow from the radiator.
Now even after I take the bike just up and down the street it seems to spit coolant out of the overflow.... Like it is boiling over...
Plz help... I am thinking about draining and refilling the radiators again... :thumbsup:
when you drained it did you drain the cyclinder head? if all you did was crack the plug on the radiator there will still be coolant in the head, this needs to be drained as well. when you refilled the system did you bleed the air out of the head? the highest part of the cyclinder head is above the lower radiator hose, if you dont bleed the air out of it your bike will constantly overheat because of the trapped air in the system. i dont know where the bleed and drain bolts are on the 08 head, but on the 07 the drain bolt is just below the exhaust, and the bleed is just above the spark plug hole on the forward side of the head. your manual should have in it the right way to bleed the system, it may take more than once to get right, with so little coolant in the system any amout of trapped air will send you into boilerland. good luck!!:thumbsup:
I have a 08 450 exc and when i replaced the radiator fluid i drained it by taking off the water pump cover. After i replaced the cover, i fIlled the radiator and never had a problem and its been about 200 miles now.
K so I think I possibly overfilled the radiator. I took some of the fluid out and it isn't spilling out from under the frame like before. It isn't boiling over that's for sure, cuz I can't hear the boiling noise from the radiator that you normally hear. Also, is the cap supposed to prevent the fluid from entering back into the overflow drain tube?
what?
you have specified instructions through the bike manual or engine manual,
there are two screws to play with, one is under the exhaust, which you open and drain the entire system into a tank or so, you can watch this being done in one of mcgoodies video's.
the other is when you fill it up again, it is just like cliffsherman said taking the air out, you fill the radiators with fluid, than open the screw and hear the air going out till some water start to flow, then close it and complete the radiator filling.
socalmedic- had the same issue, filled it up too much and got anxious over it spilling over the engine while riding,
while playing with it, took the water pump cover off as well so that was a bit worrying,
it was a great relief knowing it's nothing.
The 08 manuel tells you to drain the fluid by removing the bottum screw of the water cover, so you might as well check the water pump impeller. After that fill it up and ride. In the manuel there is no mention of air bleed screws.
Exactly what I did.... and now I think I just filled it too full... it isn't spewing anymore:banana::thumbsup:
my bad,
talking about an RFS 2006,
i'm just so dumb sometimes :thumbsup:.
:confused:
Edited by mazungo
  • Similar Content
    • By TheLastByte
      Looking for something a little lighter and faster to supplement my xr650l and I think this bike might fit the bill. I'm hoping there are some owners here who can give me some insight into the typical experience with this bike. The question I'm most concerned about is how many hours these engines last before needing a rebuild with normal trail riding? Also, how do they handle in technical terrain? How about on the road?
      The machine I'm looking at has about 75 hours and 1,500 miles on it, all stock other than a lectron carb, and comes with some dualsport lighting not installed. The current owner's asking price seems pretty high at $4500, but he seems to be a communicative, eager seller, which is practically unheard of in Upstate NY where the vast majority of dirtbikes on Craigslist are owned (or "owned") by rednecks trying to flip them. I'm willing to pay a little more than market value for this reason.
      Thanks for any input!
    • By Chad Harlan
      Hi all,
      I got a set of the Axis passenger pegs to fit my 14' 500 exc. The bike does have the alloy sub-frame, but I'm curious if anyone has used this set up with success without destroying the sub-frame or their wife/gf?
      Short trips like errands and rides out to the coast for hiking. 10-15 miles on the longer rides, and likely 0 miles on the highway, as she is not super stoked about riding. But our job kinda doesn't allow multiple vehicles. Yachties. Also shopping a sumo set up at the moment too.
      Thanks folks!!
    • By Bryan Bosch
      Recently,I took a trip out to Colorado for some R&R on a family vacation. I brought my riding gear and had planned on renting a bike, but I was too late and at least what I looked at, there was no availability for my timeline. Bummer, since I'd not ridden the rockies in over 4 years, something pretty special when you live in flatlanderville (Florida)!
      But, behind the scenes, a couple of TT'ers were at work! Through TT, we recently hired a fine, young gentleman to head up our advertising sales team,( @Freemotion ) and he pulled some strings with a local who had a well equipped  KTM 450XC-W that is his back-up machine. His new love is a 2019 KTM 300 TPI and it was gorgeous!
      So, a HUGE thanks to @Freemotion for greasing the skids in getting me a skoot and to @G 9.5 for generously lending out his bike to basically a stranger. The weather was great, so was the company, and the riding was epic as far as I'm concerned. I'm still a bit humbled by the generosity, so I wanted to share a story that I bet isn't as uncommon among the riding community as one might imagine.
      Dirt bike people rock! 🤘
    • By JacksonDRZbeast
      Hello TT peeps. I currently have an 11' Ktm 450 exc which i am converting to sumo. Still on the fence about getting cush drive rims or standard rims. Not too much info on what cush drive does for wheelies. I know its smoother on the tranny and chain but will it make much of a difference with slower wheelies/stunting? I had a DRZ with standard rims and slower wheelies were very choppy and almost impossible to control smoothly. Any advice/tips/help will be much appreciated.
      Also.... will 5" rims be pushing it for chain rub? Should i just stick with 4.25"?
    • By scott72
      Hi, I was wandering if anybody has recently bought or sold a 2014 or 2015 500 exc?  I'm trying to get an idea as to what they worth presently.  Thanks for any help.
