2012 CRF250R Specs
HONDA 2010 CRF250R
Press release: Superb handling and excellent power stand as the hallmarks of the CRF250R, and the revised 2012 model ups the ante in the 250 class. A new cylinder head, camshaft and 46mm throttle body produce a broadened powerband featuring more low-end and midrange torque for an amazing, right-now hit of power. In addition, a new suspension linkage along with updated suspension settings front and rear bestow improved tracking and more precise handling upon the CRF250R, enhancements that make a great-handling bike even better than before. In addition to those changes, longer and wider footpegs deliver more support and Dunlop's premium MX51 tires cap off championship-caliber credentials that make the CRF250R the bike to beat in 2012.
WHAT’S NEW FOR THE 2012 HONDA CRF250
(1) New cylinder head, camshaft and 46mm throttle body produce a broadened powerband featuring more low-end and midrange torque.
(2) Updated suspension settings front and rear for improved tracking and more precise handling.
(3) New foot pegs are wider and longer for more support, and are now silver color.
(4) New front axle collars add rigidity to the front end, increasing steering precision.
2012 CRF250 SPECIFICATION
Bore and Stroke...76.8mm x 53.8mm
Compression ratio...13.2:1
Valve Train...Unicam, four-valve; 30.5mm intake, titanium; 25mm exhaust, steel
Induction...PGM-FI, 46mm throttle body
Ignition...Full transistor with electronic advance
Transmission...Close-ratio five-speed
Final Drive...#520 chain; 13T/49T
Suspension Front...48mm inverted Showa 16-position rebound and 16-position compression damping adjustability; 12.2 inches travel
Suspension Rear...Pro-Link Showa single shock with spring preload, 17-position rebound damping adjustability, and compression damping adjustment separated into low-speed (13 positions) and high-speed (3.5 turns); 12.5 inches travel
Front brake...Single 240mm disc with twin-piston caliper
Rear brake...Single 240mm disc
Front tire...Dunlop MX51 80/100-21
Rear Tire...Dunlop MX51 100/90-19
Wheelbase...58.6 inches
Rake (Caster Angle)...27-12'
Trail...117mm (4.6 inches)
Seat Height...37.6 inches
Ground Clearance...12.8 inches
Fuel Capacity...1.5 gallons
Color...Red
Curb Weight...227 pounds
What do you all think?
