Coil over heating issues? Cr 80
just wondering i will ride the bike for like half an hour or so then it will just bog down when it gets on the pipe then it wont start for about 10-15 minutes? possible things could this be? Reeds or even coil over heating? it is from 1982 after all and then the proces continues over and over again:ride::thumbsup:
Change the plug
as long as the coil is grounded good that shouldnt be a problem
The reeds wouldnt be affected by heat
How the carb? remove the bowl and clean the jets..... remove the fuel line and make sure gas flows out real good for awhile.
Also check your gas cap breather ..... that very well could be the problem.
