Will a 650l stock shock/ spring bolt up to 600?
I got a 99 600r and was wondering if the L shock/spring will bolt right up to the 600?
Front what I can tell it looks like it should be an even swap?? Anyone done it?
I imagine it would.
Doubt that it is any different (better).
If you just need one, then do it.
If you're hoping it's better, sorry.
I thought i read somewhere that the spring was heavier in the L because of passenger capabilities. I know riding them back to back I sure can tell a difference and I like the L's shock better, not the extra weight though.:thumbsup:
Its a direct bolt on but if remember right the L is valved/sprung softer than the R which would makes sense since one is for the dirt and the other the street. Why are you swapping
Maybe my shock is bad, but it feels like mush compared to the L even on the Hardest settings. I really noticed it last fall when I had my dirtbagz and duffle loaded on the 600 wasn't that much weight maybe 10lbs+. When I got back and took a ride on the L I couldn't believe the difference.
I bet your stock shock is shot. It is very easy to rebuild the shock on your own, the only hard part is geting the nitrogren psi set
Maybe the shock just needs charged. I just got the bike last spring and I felt like I had just bought a new xr600 at the dealer without the dealer price.:thumbsup: The bike had a couple hundred miles tops original tires etc. I put about 3k on it last summer, more onroad then off so I dont really think the shock would need a rebuild. Is there an easy way to tell if it needs charged?
Or just take the shock to the shop? I thought I ready somewhere you need a special gauge or tool to check the pressure because if you don't you'll release out the gas using a tire guage and it won't be accurate?
Yes, thanks after further inspection the seal does look bad so while I'm at it might go ahead and get a heavier spring.
