In need a cam for a 09
BTW would anyone know how to determine if the cam sprocket has slipped or rotated on the camshaft.
You would have to find the published specs on the camshaft, where it will state at which degree of rotation a certain even happens (peak valve lift, overlap, etc..), and then you'll need a degree-wheel and a dial gauge and see if the valve lift numbers match up where they should be at a given degree.
Guest
This topic is now closed to further replies.
