yz 125 with slack in back?
i have a 2006 yz 125theres a little bit slack but i cant figure out i it in the swing arm or sock bearings any ideas how to check?
Often times it is the lower shock mount bearing to go first.
Then the check should be made for the other bearings in the linkage.
Some brand new bikes have bearings go bad in the first ride or two from lack of grease leaving the factory. And many used bikes just plain get neglected. Bearings turn to dust and sometimes linkages get ovalized.
i ook the sock off and looked i was pretty dry and on one side you can see the needles and the other you can could that mean somthing?
ok i went ahead and orderd a new bearing for the bottom of the shock now anyideas how to get it out?
