susp. seting ???
hi everybody i just owned a yz250f 08 last week and i want to set the suspension click so if anyone have a setting for me it would be very appreciate ... i weight at 135pound , my susp. setup is stock and i only ride on track thx
First things first, you need lighter springs
stock is a .44kg/mm fork springs and 4.9kg/mm shock spring
I would recomend you go to a .40kg/mm up front and a 4.7kg/mm on the shock
yeah i think i will doo that
set you clickers as per owners manual and fork it from there. make sure your sag and race sag is set right
