Clutch Noise when Lever not pulled?
So i started up my 06 RMZ today after not having the opportunity to drain the fuel after riding at the track a few weeks back.
I noticed some noise from the engine are when the clutch was not pulled..
As soon as I pulled the clutch, the noise was gone..
Any ideas? Expensive to fix?
I would check the bearing at the end of the push rod first. Easy and not expensive. Then if it is good, you have the cover off the clutch and can check the plates to see if they are the problem. But I would guess the bearing by the way it sounds.
I noticed this on mine just the other day...and I only have about 10hrs on a complete rebuild. If you find the problem post up and I'll do the same.
sounds good..
