Looking for proper jetting for FCR...
My bike has a new 434 Big Bore, Hot Cams 3x3 full exhaust, and is at sea level. I'm using a used FCR 39 MX. Runs like a raped ape but can't get it to idle right. Motor races no matter what... No leaks... Nothing sticking... ??? I don't know what jets are currently in the carb. Looking for any info... Thanks!
I assume you already tried turning down the idle adjustment, if not then adjust it. You might still have a vacuum leak at the intake boot. And you need to find out what jets are in it and where your fuel mixture screw is set.
Found the problem. There is a crack in a screw housing on the top. Looks like the previous owner forced a screw in there.... hoping a new o-ring and some j-b weld around the crack will do the trick. One of the hazards of buying used... was from a member too... oh well.
