X history in pics
So I posted stuff. Yeah I know, a lot of "non-X" related posts. Sue me!
Six years ago this week. Fresh off the boat.
A few parts later, stock uncorked exhaust
Upgraded exhaust, more ergo changes
A trip to Jawbone. 280 miles in two days.
Dumont Dunes with Cam
Still had the R (the back one)
Gorman
Bought a DRZ400 (X not plated yet). Sold it in two months. Two heavy and slow.
Piutes
Bought a plated XRR and tricked it out a bit (X not plated yet)
Me climbing the "SSS wall" at Drinkwater Flats
The license plate bracket goes on the X, in anticipation! No, you can't plate them.
Had the work vans Wrapped
Three years later, no plate on the X. Sold the DRZ and the plated XRR and bought a worn out plated WR450.
Rebuilt the suspension, ergos, and rode the CRAP out of it for one year. 416 hours!
Found a DMV service in San Diego that specializes in plating Trophy Trucks.
Got a nice package in the mail 6 weeks later !!! Finally!! Before you ask, no you can't plate them. And it was very expensive.....
AIRTIME HID lighting is added. Thanks Johnny!
One of hundreds of rides to Rowher Flats
The X gets an upgrade: Top end, Stage one port and polish, Suspension re-valve (second, after ESP) and re-spring, Tach, new plastics. Thank you Agent Smith Racing!
Who says I don't know how to jet a motor>>>
Edited by Krannie
2003 plated WR gets sold. Worn out. Made $600 profit net after riding it for a year +!
Found a 2007 WR450 for peanuts, and bought it.
Bought a house in a neighbor hood that has this three blocks away, up on top of a hill, out of sight:
The '07 WR450 was a great dirt bike. But too close to the X. Got me thinking......what about buying a
REAL dirtbike again, before this one gets all thrashed??
Enter the Press Release unregistered 2008 (in 2010) KX450. $3900.00
Taller seat, flywheel weight, Taller bars
The Dynaring saga. Put the Rekluse EXP unit in instead.
Wet Cal City. Magic.
Edited by Krannie
Mod list, to date:
2005 CRF450X 4.28.05- 6.06.07
FASTWAY “EVO” FOOT PEGS
• PRO TAPER CR “HIGH” BEND BARS, GOLD
• PRO TAPER LARGE BAR PAD
• Will Change to KX High Bend (done)
• Will Change triple clamp to BRP sub-mount (done)
• DUGAS ENGINEERING COMPUTER (11.21.06) (removed due to slow operation)
• DUALSPORT.COM Stealthy Dual Sport Kit (11.21.06) (removed do to poor quality)
IMS 3.2 GALLON TANK (red)
ARC CLUTCH PERCH, RED
• ARC BRAKE AND CLUTCH LEVERS, RED
• ARC HOTSTART/FRONT BRAKE PERCH, RED
• BY-PASS OF CLUTCH STARTER SAFTEY SWITCH
• “BONZ” OVERSIZE BAR CLAMPS CHANGED to BRP SUBMOUNT
• CYCRA FULL-WRAP HAND GAURDS, WHITE (second set 1.07)
MAXXIS IT TIRES
• ESP SUSPENSION TUNING (BETTER OIL, VALVE STACK TUNING)
RACE TECH SPRINGS (.49/5.9)
• PINK WIRE DISCONNECT
• AIR BOX OPENED (TOP, FULL-TO FRAME AND BATTERY)
TWIN AIR FILTER (changed to UNI 8.09)
• BACKFIRE SCREEN REMOVED
GUTS RACING SEAT FOAM (TALL, MED-SOFT) AND COVER (COMP)
JD JETTING KIT (170 MAIN, 48 PILOIT, RED NEEDLE @ 3 DOWN)
BOYESEN ACCELERATER PUMP COVER, AND CALIBRATION (removed due to intermittent results)
• FASTWAY BLACK CASE SAVER
• UTAH SPORT CYCLE FULL SKID PLATE
WORKS CONNECTION RADIATOR BRACES
• WORKS CONNECTION REAR RESIVOIR GUARD
• WORKS CONNECTION OIL RESIVOIR TOPS
• FORKS AT “0” mm OFFSET IN TRIPLE CLAMPS (changed to 6mm 1.07)
• REAR SAG @ 98mm (this actually changed on it’s own to 165mm after 180 hours: re-set sag to 115mm 1.07)
• FRONT SAG @ 28mm
EXHAUST MODIFIED (INTERNAL BAFFLE CUT, AFTER OVAL HOLES, LEAVING ABOUT 3” OF INTERNAL TIP, NO HOLES LEFT)
• Changed to Dr. D full system exhaust 8.05.05
COMING SOON/MOST RECENT MODS
• ’05 R CAM WITH X PISTON (done 1.07)
• OR, CRF450R HEAD AND CAM (COMPLETE, STOCK) (decided WON’T DO)
• RE JETTING FOR ALL ABOVE ENGINE MODIFICATIONS (not needed)
BRAKING “WAVE” FRONT ROTOR (stock not bent yet)
• POWER NOW PLUS (DON’T NEED IT)
• BRAKING FRONT BRAIDED STAINLESS STEEL BRAKE CABLE (NOT DONE YET)
• CA LICENSE PLATE IN PROCESS 11.21.06 (still not done 6.07)
12.2007:
- GOT CA PLATE 7.15.09 !!!
- Changed fork tubes back to stock position, rear sag at 105mm and went with Dunlop 952 front 80/100 tire. HUGE IMPROVEMENT OVER ANY OTHER COMBINATION I HAVE TRIED. I am now anxious to convert to 20mm clamps and a stabilizer, for the ultimate in control and turning quality......
- 08.25.09: went down to 50 leak jet: minor small change in throttle response.
- 08.28.09: R&D power bowl 2 with adjustable leak jet. Very big improvement in off-idle throttle response, and flat spot before 'R' cam peak.
10.15.2009:
- BIKE SENT TO AS RACING FOR THE FOLLOWING:
--PISTON AND RINGS
--VALVE JOB (STEEL + STEEL + BETTER SPRINGS, SEATS, GUIDES)
-- AS RACING PORT AND POLISH
--BAJA DESIGNS STATOR REWIND
-- AIRTIME HID LIGHTING KIT
--22MM BRP TRIPLE CLAMPS AND X BRACKETS
--VAPOR COMPUTER AND BILLET BRACKET
--AS RACINIG SUSPENSION RE-BUILD AND RE-VALVE FRONT AND REAR
-- FULL RE-GREASE EVERYWHERE
5.10.11:
Re - set sag. Was way off for a long time, for some reason. Could only get 9mm/100mm. I guess I gained some weight??
Handles 1000% better.
3.11.11:
Try to fit Dynaring from KX in X. Fibers interchange, metals do not. Ordered metals from Revloc.
- Replaced worn ignition switch
- Replaced second 'dead' Vapor ($38 for a re-furb)
dude way too much time on your hands LOL
Yeah, I've been home sick for a week........
That was beautiful! brought a tear to my eye....
:confused::thumbsup:
When's the orange one coming?
I got mine about the same time as you, reg. is due this week. Wish I would have chronicled my mods like that. One major difference; the X is the ONLY bike I've had since '05.
Yeah, I know it sounds like I am spoiled beyond belief (which is mostly true), but all those 'second' bikes came from the same $3000+ or so, recycled over and over.
And yeah, Orange is probably next.
I don't own any Austrian left-handed Pumpkin tools, however.
Nice Krannie, I appreciate you sharing your experience and knowledge. Good looking bikes.
Very nice thread... That is until you mentioned the color orange! :thumbsup:
J/k.. Very nice! would love to ride with ya sometime!
Krannie, you never mentioned anything about chain and sprockets. You still going strong with the stock chain and kept stock gearing?
It's listed in the 'mods' list.
Stock chain and sprocket lasted about 100 hours, then it got 'jammed up' by a rock. I changed the chain, kept the sprocket, and went another 150 hours or so on both.
You can wear out a chain, sprocket, and rear tire in one day, if you are a monster on the throttle. I stopped doing that about 11 years ago. I have more fun riding well, than riding fast, nowadays.
I have the DID 520vt2 and the 'Supersprox" on there now, and it took about 20 rides before it even started to stretch!!
Great walk down memory lane! Hat's off to you from one motoqueer to another (Yes, Bill, that's an extreme compliment).
:thumbsup:
More random pics of X life:
The dreaded Cupping of the intake valves
Nope. Gotta go.
LNPF
What happens when you kick your bike on the kickstand: the bracket bends, and the kickstand starts rubbing a hole in your swingarm.
Back when Drinkwater Flats was open. Sigh.
One of several dozen trips to the Husky monument
?action=view&current=CalCity8906003.mp4
Sweet Bike, Mods, and pics
Nice X model . I own an 03" 450 R since julu 03". Mine is street plated. I can plate anything but an atv or utv here in New Hampshire, all that is needed is a fold away mirror, petal bike horn, headlight asleast 35 watts, working tail and brake light , kickstand is optional but why wouldn't you. I think N.H. is the last state to get away without directionals and electric horn. I do very much need a soft seat foam, I have a sdg tall but way too hard on my ass when I do road riding to connect trails. Is guts racing the only one that sells soft foam ? Thanks
Hey ah, Krannie. I rode a similiar WR450F that was all YZ-icized last weekend. :ride: Good overall pull but no power wheelie a-go-go.:thumbsup::ride: My YZ250F has the power wheelie go go but lacks the 450 broad pull of course (but it does have great snap).
Do you find the Honda to have more snap and wheel liftin' power than the WR450 or is it only found on your KX450F? I Have ridden MX bikes for too long and have learned to expect this. Will I be unhappy with a stockish 450X motor wise? I'm big and tall. :banana:
Oh ya, great thread! I have similiar records in a boring excel table however. :D
The '03 WR when uncorked and tuned with YZ cam timing has just enough power. It has good torque down low and lots of over-rev, and No hit.
The later years are slower, less suspension travel, and such.
All of them have terrible forks, small ergos,
The stock fully un-corked and jetted X has more motor, but it is more midrange-y. The X is much more suited to a big person.
:thumbsup::lol::ride::lol:
