need carb help
trying to put pwk on my 02' cr250 but i can figure out how to get the throttle cable off of the minuki...
any advice/pictures/videos are welcomed
Take the lid off of the Mikuni and pull out the slide. You should be able to see what to do then.
after you get the slide out compress the spring, make sure the plastic retainer comes out with the spring, hold the spring up away from the slide and push the cable down into the slide it is in a notch and just pull the cable out.
thank you i figured it out
