YZ 85 shift shaft question
The last 2 weeks I have gone through 2 gear shifters. My rider keeps pulling in with the dang thing sloppy pointed as far down until it bumps the frame.
I am starting to believe my shift shaft has bad teeth. My question, does anyone know if you have to split the cases in order to swap that out?
Thanks
You do not have to split the cases. Just remove the right cover and the clutch and it will come out.
Maybe the rider is landing with weight on the shifter.
Thanks GMO, I was hoping that to be the deal.
I would tend to agree with you except my rider weighs about 80lbs soak and wet :thumbsup:
Im sure 80lbs can bend that man. But i would take the bie apart and take a look at.
