power point for GPS
Has anyone ever hooked up a power point like in a car where you could plug in your GPS?
If so how did you do it?
I bought a direct battery USB style adapter for my Garmin. I powered it through a relay controlled distribution block I mounted on top of the headlight.
Ran the cable end to the right handle bar:
Ram ball mount to hold the GPS and I'm good to go.
When installed, the GPS is centered over the center of the handle bars just below the dash.
Works great. When not in use, I just tuck the power cable slack back in to the headlight shroud.
WGW
