Swingarm
do you guys think a 2002 yz125 swingarm will fit an '03 yz250f?
I compared part numbers and there close!
2002 yz125- 5NY-22110-00-00
2003 yz250f- 5UN-22110-00-00
think i can get away with using the yz125 swingarm? what are the differences?
thanks:thumbsup:
Howard, check the swingarm bolt and see if that's the same part number, then check the brake caliper and the rear axle bolt. The original 01 was built off a YZ125, so some items will swap. Due dilligence in looking up............ many gains.
according to the part numbers, yes it will work.
the first 3 are the model, the middle 5 are the actually part number, next 2 the major revision and the last 2 the minor revision.
