06 RM-Z250: problems when hot
When the bike is cold, is starts und runs great! After 5 laps, when the bike is warm, is starts popping, backfiring, and eventually stops. What we already did/checked:
- all fluid levels are ok
- valve clearances are in spec
- swapped the complete electrical system from running bike (except TPS)
- carb has been cleaned and checked
Nothing helped. We will exchange the TPS soon (but I don't expect anything since the readings are in spec).
We really have no idea anymore. Who can help us?
Thanks! :thumbsup:
Edited by FrankV
typo
Problem solved: turned out to be a clogged fuel filter, which lead to not enough fuel in the fuel chamber. It only had enough at the start. Turned out the carb wasn't as well checked as stated.
