Additional jetting for SSW/MRD
Im currently running a TT FCR 39mm with Merge APS, 3x3, KandN, and a SSW/MRD shorty. The kit came with the jetting recommended in the FAQ section as follows
160 main jet
200 main air jet
EMN needle
Clip 3
2 turns out on the Merge extended fuel screw
Pilot air removed
When I swapped out the RS2 for the MRD, it seems like my idle is a little rougher and theres alot of popping on decel. Other than that it seems to run strong. I taped off about a 3rd of my 3x3 and it seems like theres less popping but its hard to tell.
Can anyone confirm this jetting? Im at sea level and temp is usually 70-90 and a little humid. I dont want to mess with the carb if I dont have to but I have no idea how much popping is normal with the MRD or how smooth the idle should be. Im just wondering if the design of the MRD would require a jetting change over the RS2. Thanks
my idle/decel is smooth as glass...no popping... try richening your idle a bit...
