Carbon Fibre Skid plate SX-F 450 to SX-F 250
The angle at the front of the downtubes is different due to the shorter 250 motor (compared to the 450/505).
You can make it fit if you really want to, but there will be a gap between the front edge of the skid plate and the curve of the frame rails so one good hit right there will probably dystroy the carbon plate if you put it on your 250.
You may also need to do some fitting as the mounting location on the front of the plate will be different due to slightly different motor mount locations between the 250 and 450/505.
