what size is the steering stem/castle nut on a 08 crf250
That nut isn't tightened down tight, I just use adjustable plier or you can use a screwdriver and hammer and tap it. When you tighten it make sure you don't tighten it to tight or your steering will be tight.
+1
A set of pump pliers (slip joint pliers) will easily do the job.
An aluminium drift punch and a few light taps will also get it moving.
