FRC 39 jetting parts
I want to buy for my 400 E original FCR 39 some jetting parts and i have a Q .I go to Jetsrus store
EMN needle = ok
200 main air jet = ok
100 slow (pilot) air jet = ???? This jet is the same size as the main air jet ? Tue same parts listing ? If is not the same ,where i can find this slow air jet ???
Thanks .Pat
100 slow (pilot) air jet = ???? This jet is the same size as the main air jet?---No. Pilot air jet is different. Try KTM. A 100 pilot air jet may be original for some of the older KTM 4 strokes.You cam also make one if you have a smaller jet. Use a 1.00mm drill.
Why do you want one?
The 100 PAJ is commonly used when fully removing/capping off the CE from the FCR 39 slant model carb. It goes in conjunction with the OEM sized 45 PJ.
Contact Eddie at SSW/Epic for the parts. Tell him in detail what you have, what you want to do and where you live...he will get you what you need :thumbsup:
