01 CR250 Carb rebuild trouble
I ordered a JD jet kit, since they come so highly recommended.
I took apart my entire carb since I had half of the bike apart already, but bent it in the process of taking off the bottom portion- where the floats are. There's only one screw, on one side that holds this to the carb and up to the seal, which made me wonder why there aren't two- and made it obvious why this screw was so difficult to get out.
Anyways, I used some gasket maker and put it in a vice to hold, and was thinking that this part isn't high pressure so there probably won't be reason to replace the entire carb.
Am I right, or is it totally shot?
please no replies from people telling me about better carburetor options, I know there are better carbs but I'm not going MX- I trail ride for fun and don't want to dump all my money into this bike. If you think this will or will not hold, and what I should do once I get my JD kit for an extra-rich running bike at 2-3000' elevation, lots of spooge action. May get a gnarly/platinum fmf in the future too- dunno. That will probably require a rejet if I do.
Thanks fellas!
I'm confused as to exactly what you are describing here. What exactly did you bend?
Had to check the term in my manual, make sure I have it right for you.
The float bowl, bottom metal portion of the carb- it's bent from where it was connected to the opposite screw. So pretty much a bit of the bottom of the internal housing, I think the gasket maker would make it leak proof but not high-pressure proof.
