What mods would I need for this KDX220?
Check this one out ... http://fresno.craigslist.org/mcy/2354910418.html
If I buy it, I'm wondering what mods i would need to do since its bone stock.
I'm thinking:
Stiffer fork springs
tall seat and RC high bars (I'm 6'4)
Just wondering what all I would need?
I'm not a racer so I'm not going to go crazy and squeeze every last HP I can get from it. Just looking for for the bare minimum mods to make it solid and fun. Hoping to keep my budget around $500 on mods, but willing to do more if its really worth it and necessary.
Piston Change to a Wiseco (for security as the stock ones break) <$150 if you do it yourself.
RB Carb and Head mods = $215. Huge Improvement.
Boyesen Reeds = $35
Remove airbox lid = Free
These will greatly improve performance.
You can also swap out the forks for 96 up KX forks = ~$300.
seems like the RB carb and Head mods is as much as an FMF desert pipe. which one is more bang for the buck in terms of performance?
Boyesen Reeds = $35
except for the wiseco, i completely disagree. he needs to work on the suspension. the kdx suspension is wallowy for the lightest riders, at 6'4" i doubt he falls into that category.
i would do a wiseco, springs for your weight front and rear and freshen up the suspension. if you have money after that, a fatty or ganrly desert type pipe, and a decent silencer. kx front end is a good option.
I fixed the suspension on my 220 before I did anything else. I put in heavier fork springs on the front (they have .35 stock so I put in .38 for my weight) and a Racetech Gold Valve kit. The front end is both firm in the big stuff and plush and straight tracking though the loose rocks. I had to go lighter on the rear spring (4.6 in place of the stock 5.0) and the shock also got the Gold Valve treatment, though the stock shock valving is better than than the stock fork valving.
Then I added the FMF desert pipe with a matching FMF spark arrestor. Makes the bike hit softer on the bottom and then have better snap at top end.
Later, I put a Steahly flywheel weight on, mainly to help keep from stalling the engine so easily when using the touchy rear brake. It won't do anything for the low end power in combination with the rev pipe though.
I also added a Fredette Racing one piece handlebar clamp which makes the bars feel a lot more solid than the two stock clamps did.
And yeah, I put in a Wiseco at the first topend rebuild.
I'll jump on board and say Wiseco, bars, tall seat, and springs for your weight. Plus any other maintenance items it may need (chain, sprockets, reeds, tires, brake pads, etc).
If I got a KDX220R, the first thing I did would be the Wiseco piston. Soft fork springs and too-low bars never left someone pushing a grenaded engine back to the truck.
After the piston, get the bars and fork springs. Don't worry about a pipe or other stuff until later.
  • Similar Content
    • By jace kornegay
      I have a problem with my stage 2 exhaust cam on my rmz whenever I kick it over the exhaust cam likes to stop at the lift unless I put it at tdc or kick it really slow it runs fine when it starts and I have played around with the shims right now all the valves are shimed and I have checked the timing everything’s to spec it just gets stuck at the exhuast I’m pretty sure it’s something to do with too much compression I probally will end upbuying stock cams but wanted to see if anyone knows how to fix this first
    • By frontline510
      I recently acquired a 1990 KDX200. The bike runs reasonably well for it's age. The first ride over 30 min the gearbox oil started overflowing into the airbox (overflow hose is routed to airbox). The oil that overflowed and the oil in the gearbox are an odd shade of dark forest green. The oil appeared to be overfilled slightly which explains the overflow. What I don't understand is the weird dark blueish greenish gray color of the oil.  I believe the PO used motul 10w40 ester gearbox oil because he gave me a half used gallon. I use Motul 710 2t oil which is blue, and run green coolant in the radiator. I drained the gearbox oil and there was a nice little clump of dark gray metalic paste on the magnetic drain plug, which should explain the gray hue. What I do not understand is the greenish blue hue. Anyone know what in the heck is going on with this old horse?
      The pic shows a sample of my drained oil. When held up to the light it turns more of a green color. Oil still feels slick as can be.
    • By 2strokeKyle
      I am wondering how a kx125 will do at at Glaims. I am 14 years old 5 foot 4 inches  and 100 pounds. I will have a paddle tyre in the back too.
    • By Snox90
      will a clutch basket from a 98kx250 fit a 96kx250? How about the carb also?
    • By Kaelan Frost
      I have a new cylinder that i bought to rebuild my 1993 kawasaki kx250 with, because the old cylinder was destroyed. The guy said the cylinder is overbored a little but never gave us numbers. The new one i bought came with a piston thats been used and i would like to replace. I believe the piston that came with the cylinder is the correct size, but it very well could be off and i have no way of knowing. So how do i properly measure the cylinder bore, and how do i use this measurement to find what size piston I need to get?
      thanks,
      Kaelan
