2008 YZ250F Suspension interchangeable???
I have a 2008 yz250f and I have put a lot of work into the suspension (resprung, revalved, etc.) Also, I put a YamaLink lowering link on the bike. The YamaLink website implies that the rear link I have will fit 2005-2008 yz250f.
I am buying a second bike, and want to make sure my suspension, including Front and Rear, and the lowering link, are interchangeable. Will the forks, rear shock, and lowering link all fit on any YZ250f that's 2005-2008? Thanks in advance for your help.
it will most likely fit just fine within the same generation of aluminum framed bikes (2006-2009), you might however have to use different front brake calipers or caliper carriers depending on the year. But for the most part, yes, it will fit. Wasn't 2005 still steel frame? If so, it probably won't fit.
