Rubber Blinkers
so ive been very disappointed with the durability of the stock blinkers, i tried relocating the rears up toward the seat so they didnt hang out so far but still have busted 3 out of 4 and now have electric tape wrapped all around them trying to keep them together, kinda works for now. im wondering why they had the good idea to rubber mount them and make them flexible, but then made the outter housing out of something the equivalent of egg shell. one good tap from a rock or branch and they shatter. does anybody make a solid rubber blinker? rubber flex mount and rubber housing? the only thing that really needs to be hard plastic is the lense in my opinion, the rest should be rubber. anyone know of blinkers like this?
You can see where I mounted my blinkers here:
If they broke in a fall they would be the last things i'd be worried about.
The only issue is the right blinker needs a standoff, its slowly been melting on my muffler. The previous owner had them setup this way and I just never bothered to change it.
thats exactly where mine are, there were already holes in the frame and they mounted perfect, a lil close to the muffler though your right. i just want to find some solid rubber ones.
so far ive dropped the bike a few times and dumped it over backwards a few. the only things ive had to replace were handlebars, and all my levers are bent but still working, but the blinkers seem to be the weak point. im gonna have to buy new ones soon and was hoping to find some solid rubber ones.
i have them mounted in the same place for the last 4 years and 17,xxx miles and dropped a number of times and all the above and have yet to crack/break one. thewy get kicked all the time when i try and mount the bike with boots and still going strong. i have a MRD and my blinker is resting on the muffler and has yet to melt
I had to replace one of my DRC 601 blinkers that I destroyed in a crash last year. Instead of using the hard plastic spacers that came with the blinkers, I used some black rubber fuel hose that was lying around and cut my own spacers. It gives them a little flex now instead of being so rigid.
  • Similar Content
    • By Bignerd0100100
      Hey all,
      I'm looking at buying a 2004 Suzuki DRZ400EK or at least I think it's an EK according to Vin lookup websites, but it does not appear to have a kickstarter. I was told the bike was owned by a motorcycle dealer and that it has a current green sticker, and a California license plate but has not been registered for the streets since 2011. I want this as a dual sport but am not clear if the fact that it already has a plate means I am good to register it or if maybe they took away the ability to register it after it was plated, California loves to do that kind of stuff. Since the bike was owned by a dealer I would think they were up on the latest regulations in California, but who knows. Can anyone add any insight as to what I should look for on the bike itself like the carburetor, model numbers etc? Or do I just try my luck at the DMV?
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
