69 Honda CT90 Throttle Cable
Can anyone tell me if any other years will fit a 69 ct90, Honda has discontinued the cable for the 69
Back in the day, when we ran into that kind of problem, we built out own cable from bulk parts and soldered the ends on them.
I would try that but i dont have an old cable to compare it too when bike was given to me it was missing several parts
If you have to make your own, I've found that Flanders co. Is a good place to buy bulk inner and outer cable and various ends to solder on. Check out their web site. You should be able to size it yourself by routing it properly and checking steering, lock to lock, etc. I can just about guess what ends it had on it. There aren't THAT many different ends for a throttle cable. Good luck!
The K2 and K3 cables will work, though they are slightly longer. These guys may have what you need:
http://www.dratv.com/
Ok thanks everyone i will check it out
