06-11 triple clamps work on 05 yz250?
Bike looks good
Plus 1!
The 2005 lower triple clamp has a slightly different pn (1P8-23340-L0-00) than the 2006-up (1P8-23340-M0-00), though I don't know the exact differences between them. Like jeffro667 said, I've heard the distance between the fork legs was different (2mm?).
The '05 & '06 share the same front wheel spacers (5NY-25183-00-00 & 5NY-25186-00-00), so maybe the spacing difference was made up in the lower fork leg bosses, which are different (1P8-23120-L0-00 vs 1C3-23120-M0-00). :confused:
So it seems as if 2006 & up triple clamps will work as long as you add a 1mm shim to the brake side spacer, or use a 2006 brake side lower fork leg. :worthy:
http://www.ncy-motorsports.com/fiche_section_detail.asp
There are lots of other threads on this swap. Keep us informed on what you find! ?
