92 yz250
So I got this bike last weekend,92 yz 250,got it from the original owner with title.He said it has a kustom kraft 265 big bore kit,and it does have the kustom kraft engraving on it.I got the bike for $500,gonna do the plastic this summer then worry bout the motor over winter hopefully.So my ? is will the plastics off a 93-95 work or any newer,what years are interchangable as far as motor parts.Any help would be great as this is my first yamaha in 15 years
93 up is different for sure, most parts are like 90-92 and some might be 88-92
plastic's are not too hard to find new just look around a little.
I've got a list somewhere of all the various aftermarket plastic options I can post up later for the 92. I've been researching for my WR250.
Put a wr bottom end on that thing, if you trail/desert ride. did it to my 97 and love it.
That would be cool if you could post those been lookin for some different graphics/plastics options,thats mostly whats needed as of now on my bike.
I haven't had any luck tracking down graphics, but here's what I've found for plastics for the 92 WR250:
Front Number Plate - OEM PN 4DA-23485-01-00
Acerbis white - TR PN 73-6041
Acerbis blue - TR PN 73-6044
UFO blue - TR PN 11-6511
UFO white - TR PN 11-6433
UFO black - TR PN 11-6447
Fitment based on Yam PN cross-referencing, no one lists a 92 WR250...
Front Fender - OEM PN 4DA-21511-00-00
Acerbis blue - TR PN 73-6114 - PU PN 15-8040-82
Acerbis white - TR PN 73-6109 - PU PN 15-8040-06
Acerbis sells the same PN for: 92-99 YZ125/250 92-99 WR250 98-99 WRF/YZF400
Polisport blue - WPS PN 64-5538
Polisport sells the same PN for: 92-99 YZ125/250 98-99 WRF/YZF400
UFO blue - TR PN 11-6402
UFO white - TR PN 11-6403
UFO black - TR PN 11-6443
UFO sells the same PN for: 92-99 YZ125/250 98-99 WRF/YZF400
Rear Fender - OEM PN 3XJ-21611-02-00
UFO white - TR PN 11-6475
UFO sells the same PN for: 91-92 YZ125/250 should fit, 92 WR250?
Radiator Shrouds - OEM PN 3XK-21741-01-00 and 3XK-21731-01-00
Maier white - PU PN M59989
Maier sells the same PN for: 90-92 YZ250 and 90-93 WR250
Maier has them on close out!
Rear Side Plates - OEM PN 3XJ-21711-01-00 and 3XJ-21721-01-00
Maier white - PU PN M23476
Maier sells the same PN for: 91-92 YZ125/250 and 91-93 WR250
UFO white - TR PN 11-6420
UFO sells the same PN for: 91-92 YZ125/250, based on Maier 91-93 WR250 should fit
Fork Guards - OEM PN 4MX-2314J-L0-00 and 4MX-2314H-L1-00
UFO white - TR PN 11-6565
UFO black - TR PN 11-6448
UFO sells the same PN for: 91-95 YZ125/250, based on Yam PN checking they should fit 92-97 WR250 also
Rear Mud Guard - OEM PN 39X-21642-00-00
Maier red - PU PN M20875R
Maier white - PU PN M20875W
Maier sells the same PN for: 86-95 YZ125, 84-95 YZ250, 90-96 WR250, 84-90 YZ490 and 91-93 WR500
Kurlon,thanks for the info I will def. use it:thumbsup:
Would be nicer if you just put it back together like a factory fresh 92 bike. Or make a damon bradshaw replica.
One other tidbit I found yesterday: Yamaha is obnoxious and only sells pistons and seals for the front caliper, but nothing else separate from the whole assembly. 93 Suzuki RMX250s use the same caliper... but Suzuki lists every individual part, including the bracket pins, all the rubber bits, etc.
Kurlon- Thanks will def. remember that
DMC707-I was thinking about the factory look,but I like the ideal of a Bradshaw replica thanks
