Since my bike is down anyhow? Anyone have mod ideas?
Well since my bike is gonna be down for a bit I figured I would do some other mods while I'm waiting on parts and working on getting her back into running shape. I am going to post a list of things I have to have and some things that I think I might add since I am replacing parts anyway.
What I NEED:
Head pipe
Skidplate
Odometer
Handlebars
Bar risers
possibly triple clamps
I haven't torn all the broken parts off the bike yet as I am having a hard time getting around. I might find other broken parts, but that's the list of what is obvious. Bike starts and runs fine so that's good.
Parts I am thinking about adding since I'm working on it anyhow:
Aftermarket silencer
Bark busters
Radiator guards and braces
Jet kit
Cut airbox
Anyone have anything to add while I have the bike out of commission? I would like keep it simple and not go too crazy.
The following parts are MUST DO and not a consider...
Jet kit
Cut airbox
Do these the same time you replace your broken parts.
:thumbsup:
How about a wheelie bar:smirk:
Haha, good call! I could probably benefit from one. :thumbsup:
Well, now that I am finally all healed up, and have all my parts together, other than the skid plate which I am gonna order tonight I can get to work on the bike. I ended up getting some Pro taper Countours, Cyrcra barkbusters/handguards, the JD jetting kit, Zipty fuel screw, and an MRD full exhaust. Excited about getting back in the saddle.
Jet kit
Cut airbox
:eek:
Make sure it's a BRASS fuel screw, not aluminum
Add a 50 leak jet
Don't forget the accelerator pump spring upgrade ('07 and earlier)
Thanks Krannie, why is the Brass screw such a big deal? Are the alum more prone to break? I have been searching the jetting thread and see a lot of different setups. What would you recommend for mine?
'09 X, usually ride from 1000-3000 ft elevation, mildly cut airbox, full MRD exhaust, was planning on sticking with the stock (45) pilot, 170 main, and a 50 leak due to your advice. Sound about right?
Aluminum corrodes and breaks. No fun trying to get that little tip out of the carb body.............
Your set up sounds perfect. Now hunt down an '02 R cam and drop that in there for instant steroids.
I take it you've experienced that little adventure? Haha, doesn't sound fun...
Well, I just ordered the R&D flex screw. What a PITA the stock screw was to get out.
ha, to be fair the whole carb and engine are a PIA to work on with this bike!
Haha, yeah I am experiencing that first hand, stuff is packed in there quite tight. After reading about some peoples experience with the fuel screw, I'm sure glad that the o-ring, washer and spring dropped right out with no issues for me. lol
You should be grateful. The Yamaha YZ's and WR's are twice as difficult to reach......and use a cheaper version of the FCR CR-MX carb, which is just plain not as good.....
Well, I got to take a little spin in a field by my house, nothing big, but got to open her up a couple times. WOW! Uncorking these bikes really helps. Starts easier, idles better, quite a bit more power, sounds great with the MRD exhaust. Can't wait to actually go out and ride! I am sticking with the stock leak jet right now, but if I encounter any problems I have the 50 on order, 4 different places locally didn't have one. :eek:
