Will a black OEM 2007 DRZ400SM Rear Fender fit on a yellow 2006 DRZ400S?
So I took peoples' advice and got the black Acerbis kit and I am not very happy with it.
I openly said I was a newb yet nobody even mentioned that the rear fender from the kit would not fit on my bike without major alterations. Anyway, I cut the hell out of the thing and also scratched it the F-up and dont even wanna bother with it anymore.
So, can't I just order the OEM rear fender from the black 2007 SM model and swap that right in? And if so, which one do I want? The Model K5/K6, or K7?
K5/K6: http://shop.thumpertalk.com/oem.asp?partcategory=432829&manufacturer=5&category=3&year=2007&model=10128
K7: http://shop.thumpertalk.com/oem.asp?partcategory=432830&manufacturer=5&category=3&year=2007&model=10128
Also, what about the front fender too? The Acerbis fit fine but I thought it was gonna look more sleek than the stock S fender, but it's identical. I wouldn't mind putting the SM front fender on as well.
Thanks.
Yes, the S and SM are the exact same bike except for the swingarm, forks, bars, wheels and front brake rotor (and a few minor other parts. All the plastics/tank are 100% interchangeable.Model year does not matter. AFAIK, they are all the exact same shape.
Thanks.
next time, try a blow torch and a razor... for cutting plastic, it's the shizzle.
i've had rear and front fenders from non suzuki bikes on mine. takes about three shakes with a hot razor and no whining really.
Edit. Sorry. I misread. I know the SM fender is the only on that bolts onto the SM with no cutting. I believe the subframe is different. Not sure about the S model
pros of cutting the fender:
-you can spend more time with your bike
-you can get high from the fumes of the melting plastics
-you can curse yourself for not buying the OEM S/SM rear fender
been there, done that..
gave away the Acerbis rear fender free for a guy that came to pick up after buying the OEM one from stockist..!! :thumbsup::banghead::confused:
S and SM subframes are the same and yes they bolt up :thumbsup: The E rear you have to cut :confused:
:worthy: Thanks Debi. I knew it was different than somethin! lol
Thats just the year..... fenders are the same :confused: besides colors :thumbsup:
Seems there would have to be a difference considering they each have their own pages, part numbers, and different prices. I don't wanna mess this up again.
Motorcycles » Suzuki » 2007 » 2005 DR Z400SM
Model K5/K6
FENDER, REAR (BLACK)
63113-29F41-019
$67.86
Model K7
63113-29FA0-019
$87.33
Your thinking to hard... All the S and SM rear fenders are the same even the years. :thumbsup:
If I was thinking hard enough I wouldn't have wasted money on a rear fender that doesn't fit.
It seems K5, K6, and K7, mean 2005, 2006, 2007, but the diagrams show the K5/K6 as different from the K7, and also a $20 difference.
29-1 TAPE SET - 68170-29F00-DWA - $18.01
Edited by Excite-Bike
29 looks like the stock graphic sticker.
To see some aftermarket black front and rear fenders at around $65 per set look at dealers catalogs on kimpex.com
I ordered both last week and got black for s or SM model- avoid the E model and you'll be fine. Got the cool looking KTM looking one for the front.
Just a sticker/graphic change :thumbsup:
If they are identical then I wonder why one is $60 and the other is $80.
Anyway, I just ordered the $60 K5/K6 version.
Thanks.
lots of idiocy by the oems that cant be explained.
why are the klx 400 parts generally cheaper when its the same bike?
