2003 CR85RB will not Crank
So I put together my bottom end and the rest of the engine after installing a new crank shaft. There is a brand new spark Plug in the jug getting spark (I pull the plug out and touch it to the case and kick it, I see a blue spark bouncing back and forth in the gap.)
I have even tried starter fluid, and it does not light. Any suggestions?
Fuel? Air? You need more than just spark. Did you clean the carb? Could be a clogged pilot jet. Freshly cleaned/oiled air filter? Are the reeds in good shape? How is the pipe/silencer? Any clogs, maybe silencer could use repacking? Piston and rings were installed properly?
I mean, would it not start off straight starter fluid? I tried it with out the carb connected first, the carb is cleaned out. I have not flooded the engine, I kept the gas tank off of it but for when I tried to start it with gas.
Could compression be a problem? I did use the original piston and rings as they looked fine and were pretty flesh with the bore.
UPDATE:
I pulled the read off and it seemed clean...? I wiped it off and picked up both flaps/ reeds. I sprayed starter fluid into the bike and after a couple kicks it shot white smoke, but only fired once. The smoke was definitely caused by the starter fluid, I am aware of that. It would not start after that.
New crankshaft, yet no new or reconditioning of top end. I would seriously reconsider where I was at there. It just makes no sense to freshen up a lower end, yet leave the top in question. Even if it would start, neglected top could ruin your new bottom.
The top end is within Honda's recommended specs. The piston has been replaced before and looks fine.
  • Similar Content
    • By D.Barrett
      Kicking around the idea of selling my CR250. I have other bikes and never get a chance to ride this one.
      This is a well-maintained bike with tons of aftermarket parts. It's set up primarily for woods/single-track riding, but will still do just fine on an MX track.
      Engine:
      -Fresh Pro-X top end(<1 hour)
      -FMF Gnarly pipe & FMF Shorty silencer(<1 hour on fresh packing)
      -PWK Air-Striker Carburetor(bought new from JD Jetting last year)
      -Steahy 10oz. Flywheel Weight
      -Boyesen Rad Valve with Carbon-fiber reeds
      -TwinAir air filter
      Misc:
      -Excel Pro-Series Wheels(19"/21")
      -Brand-new Shinko tires(546 Front, 505 Cheater Rear not mounted yet) w/ Heavy-duty tubes
      -Works Connection Radiator Guards
      -Skid Plate
      -FMF Factory 909 Handlebars
      -Polished Frame
      -Sunstar 13/51 Steel Sprockets(new in box)
      I'm sure I'm missing a few odds and ends. Comes with a Bill of Sale only. (708)287-1998 - Dave
    • By waldo
      Parting out 2000 cr 250r: frame 150.00, seat with brand new fx cover 30.00, sub frame 30.00, pro circuit works pipe 50.00, kick starter 10 bucks, tank with shrouds 30.00, rear shock 45.00, swing arm 40.00.  make offer on all other parts in picture. Buyer pays shipping from 36092 zip.
    • By BabyGroot69
      Hello,
      I could not seem to find a similar thread so if one exists I apologize. I have an 02 cr250r with an 01 motor. I need to buy a new silencer with a spark arrestor because the current one does not have one. I am not sure if the owner before me used an 01 or 02 silencer because I have read the frame had significant changes from 01 to 02. Any thoughts? Thanks!
    • By Christo6060
      I want to restore a 1996 cr80 that doesn’t have any graphics and absolutely love the 1994 cr125r tank shroud graphics, I can’t seem to find anything that fits the cr80 with those graphics. I found one last week but lost the page and couldn’t track it down again, do the cr125r graphics fit the cr80 tank shrouds? or does anyone know where someone could make them for cheap or know about any in Australia
    • By cerialsledder
      Hey guys,
      Could someone please explain the numbers on a needle jet for a mikuni carb?  I'm currently running a 38-73 needle but a lot of the people I talk to say I would be happier running a 38-70 needle.  I don't have a problem with going with what other recommend but I would like to understand the numbering for the needles first.  I understand the nozzle sizes, main jet and pilot jet it's just this damn needle thingamobob
      Thanks a lot
