95 XR250r rear rim
Hey guys,
I have a XR250r 95 model with a 18x1.85 32 spoke rim, which is cracked beyond repair, Trying to find one of these is proving to be extremely difficult!!
Are there any alternatives to this rim? or somewhere you know i maybe able to source one or a complete wheel? Any suggestions would be greatly appreciated
i just want to get out and :thumbsup: again!!!
Sorry to hear about your rim, same thing happened to mine,,
Luckily mine was able to be welded up as it wasn't overly bad.
Good luck and let us know what you end up doing
Don't know if they will post to NZ but I have great success with
www.findapart.com.au
All you do is plug in what you're after and they send an email out to all the wreckers etc on their database, then if anyone has what you're after they shoot you an email with the cost of item and delivery.
as long as the axle matches, won't the later years work? 2.15" isn't that much wider. Shouldn't be hard to find one, where are you looking?
Hey guys thanks for your replies! I have looked at getting the 2.15 but have been unable to find a 32 spoked one, :-|, I'll give findapart.com a go and see what i come up with....
I tried buying a used wheel when mine broke,,
I got Quoted $500 for a new, aftermarket rim, all new spokes & nipples and assembling and trueing on my hub
So i rang my local wreckers (JDK Motorcycle Wreckers) and they wanted $450 for just a wheel! No disc, no sprocket, no tyre! So i told them where to go!!!
I found one on ebay lately, in much better condition then the one from the wreckers, and at half the price!!!!!!!!
Take your time searching and get yourself a deal!!
I got a good response from findapart.com< all wanted around $500 AUD plus another $88
for a second hand complete wheel minus the tyre, which i think is a bit expensive! I sent out about 20 emails last night and Econohonda in Auckland NZ got back to me and can source me a brand spankin new one (rim only) for $250 NZD plus $20 frieght and i can have it in 2 days!!! DAMN LEGENDS in my book!!!
Thanks for all the advice guys - much appreciated
I think the 95 xr250 rear wheel is the same as all xr250's xr400's on .
Check part #'s but I'm pretty sure.
They go for anywhere from 80-250 bucks on fleabay, their like gold and guys know it.
Older xr's are the same outer rim and can be bought for a lot less money but have a different hub . If you know how to re-lace a wheel maybe thats another way to go .
Always check part numbers .
  • Similar Content
    • By 661Bran28den661
      What’s up guys. Totally new here picked up an XR400R I live in the desert so I’m riding often and enjoy it. But I am having some issues with my  01 XR400R. I brought it out this morning for a putt and it seems to be choking up in the top of second. Like a bog an go bog an go. First seemed fine and third I didn’t make it high enough into the rpms to see. Before I brought it back to the garage. Yesterday I also changed the air filter back to an uni. I had seen the other one had a hole in it and the box was dirty gunned up and oily. I removed the airbox gave it a good clean out wiped everything down very well put a piece of screen over the snorkel Or where it used to be I should say. “Lightly oiled the filter.Also the spark arrester an tip for the bike it did not come with I ended up making one with a piece of flat steel and drilling holes. Whilst doing this. I found also a crack in the pipe. It almost sounds as like there’s a vacuuming or whistle? When revving.The first one I had made worked fine I had no issues. This one I am wondering maybe if it’s a cause of a little too much back pressure.So I’m assuming it’s either a Carb or exhaust problem. Or something that could totally be minuscule. Or major issue. Would definitely like some second opinions and any advice would be greatly appreciated. Thanks guys!
      TWISTIN THROTTLES & CRACKN BOTTLES
    • By ddickinson
      My lanky 14 year old boy started showing an interest in riding MX/Off-Road so I sourced the best beginner friendly, yet dirt worthy, bike I could find: an Ol' Honda XR250R (2004). So far I've replaced a few clutch levers and perches with stock parts. That's gotten old and I'm looking to upgrade to an ASV or Torc1 type fold-able clutch/perch brake combo. Went to purchase online today and to my surprise there were no such parts listed for the XRs. I saw plenty of CRF/CRF-X choices and they seem to differ depending on generation. Obviously I can use nearly any perch/clutch combo as long as the two match; but I was wondering if anyone knew which of these levers was closest to stock? Also, will the first gen CRF250X brake lever work on the XR? These may be stupid questions to some; but I'd rather ask a dumb question than drop money on an ASV brake lever I can't use. Thanks for any help.
      #xr250r#hondaxr
    • By TheLastByte
      Im currently in the market for an xr400r, and considering buying one that's had some heavy engine work done. The current owner claims to have bought it from a friend who's an XR enthusiast. The PO installed a big bore kit and high comp piston, as well as a xrs only pumper carb, rsw triple clamp, aftermarket clutch, street lights, and a whole bunch of bling.
      My main concern is the effect the upgrades will have on the engine's longevity. How much quicker will I be going through top ends with the setup on this bike as opposed to a stock setup, and should I be worrying at all about bottom end longevity as well? I wouldn't mind having to eventually redo the top end, but I don't want to deal with a race bike type top end rebuild schedule on an XR.
      Is there anyone here who's running a bike similar to this one who can give some advice?
    • By Ralph303
      I have a 2001 Honda XR400R. It has a whirring/grinding sound in the lower end and a vibration in the top end. I pulled the valve cover and everything looks good. Decompression lever looks to be in order. Anyone know where I should start looking or just rebuild the whole engine. Ballin on a budget, but really love this bike. It looks like it’s new otherwise. Oil was jet black and thin. Thanks in advance!
    • By junglePIG
      Hi, I have an Xr250r with a buckled/ wobbling front wheel, after trying to true the rim i have broken a spoke.
      I am wondering if it is possible to lace any 36 hole aftermarket rim to the oem hub, also will i need to buy an xr250r specific spoke set. also could i take a 36 hole rim from another front wheel and lace that up???? thanks
