Easy Stebel Brackets
I tried the upper bracket first (standard aluminum stock: 3/4" X 1/8" X 3'.. $4 @ HD) but didn't like the way the horn vibrated, so back to Home Depot for more aluminum stock. Because this bracket was going to be a lot longer I went with 1" stock ($2; they had an offcut :thumbsup:, the price for the regular 3' is about $6.50)
I put the stock in a vise and bent it by hand after measuring how much space I had to work with, and then, with a little bit of drilling to the right hole size, a little bit of grinding to take off the corners and to clear the lower bolt in pic #1 we're done... well almost.
I took the tank and panels off the bike in order to wire the relay into the system and to get at the original horn wires. Fortunately the removal of the tank provided access to swing a wrench on the nut that holds the horn to the brackets. It's a pain to get it real tight with the tank on. With the original bolt supplied by the Stebel distributor, there's not a lot of it left after adding 1/4" of brackets, enough, but not a lot. Time for blue loctite.
Now all I have to do is remove everything and put the brackets to the polisher after filing everything smooth. My buddy/helper/supervisor, Stu the Jew (who at 75 still cranks it daily on his BMW 1100 RS and chases women endlessly and successfully) says to leave it the F*** alone because no one will notice.
I told him I'm having them anodized red! :worthy:
My thanks to previous posters who addressed the problems of location/installation of the Stebel. I'm once again indebted to knowledgeable members of this fabulous forum. :confused: Here's some pics.
http://i1090.photobucket.com/albums/i374/alanoutaoz/P1040752.jpg
http://i1090.photobucket.com/albums/i374/alanoutaoz/P1040750.jpg
http://i1090.photobucket.com/albums/i374/alanoutaoz/P1040766.jpg
HaHa, I have a friend like Stu the Jew, Fred also 75 who can outride most half his age! Thanks for the Stebel mounting tips.
  • Similar Content
    • By Bignerd0100100
      Hey all,
      I'm looking at buying a 2004 Suzuki DRZ400EK or at least I think it's an EK according to Vin lookup websites, but it does not appear to have a kickstarter. I was told the bike was owned by a motorcycle dealer and that it has a current green sticker, and a California license plate but has not been registered for the streets since 2011. I want this as a dual sport but am not clear if the fact that it already has a plate means I am good to register it or if maybe they took away the ability to register it after it was plated, California loves to do that kind of stuff. Since the bike was owned by a dealer I would think they were up on the latest regulations in California, but who knows. Can anyone add any insight as to what I should look for on the bike itself like the carburetor, model numbers etc? Or do I just try my luck at the DMV?
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
