quick chain sprocket question
i have stock 13/52 sprockets with only 20 hrs so still like new. i ride mostly slow technical woods in pacific nw. Is 49 or 50 my best bet prolly.. to help make gears less gappy? I find 1st gear too low anyway.
Q #2- if i get a 49 or 50 tooth sprocket is it best if i remove one link?
smaller rear will make them more gappy, but you may find you then use first more. Its a tuff call and you just have to try it and see how you like it.
I think the 51T is just about right. Tried a 50 and didn't like it.
from what ive read on TT sounds like alotta people switch it out to a 48 or 49. ya i might just have to try and see for myself. Maybe a 49 or 50. 48 too big a change if i dont like it, 51 maybe not enough change ??
Just try a 14T front sprocket to see if you like the change to a 48. Cheap way to try it out, as it's close. 14/52=3.71 13/48=3.69
I had problems where 4th was too high and third was too low. After the change to a 51T it's right about right. Maybe the guys in more open areas can run the rear sprockets 49 or 50 but not me.
Lol, Im going the opposite direction. Drop to 12t in the front and now have a 54t rear on order.
