Gas Cap Breather Hose
i have had numerous threads about my bike breaking down after 10-20 of riding and so many people replied the gas cap breather is faulty or ride with it a little loose why would a faulty breather hose affect a motorcycle Engine? cheers
EQ
(1982 honda cr 80r)
you need to let air into the tank to replace the fuel that has been used. if not it creates a suction and no more fuel will come out and the motor dies. the easiest way to check to see if that is happening is when it dies immediately loosen the fuel cap, if it sounds like its sucking air then your vent isn't working:ride:
thanks :thumbsup:
