how to jet a kiehn fcr-mx for 2500 ft???
never been inside an fcr carb but im wondering what jets wlould be my best bet for running around 2500-3500ft +-, where to set my needle(if it even has a needle)?
the bike has a 440 athena HC stage1 cams and a full yoshi rs2
where did the carb come from?
I live in spruce pine NC (2500ft) and its coming from Columbia SC (314ft)
I ride up to about 4000ft very little
no,what is the source of the carb?
he bought it from here and followed your jetting specs>>>its a 39mm
152 main jet
200 main air jet
EMP needle
clip 3
45 pilot jet
no pilot air jet
2.25 fuel screw
152 main jet
200 main air jet
EMP needle
clip 3
45 pilot jet
no pilot air jet
2.25 fuel screw
this i what I need?
if so, where can I buy just single jets that will fit and Whats an EMP needle?
that is what you need. you may or may not already have some of it.
EMP needle is the needle you need. you probably have a EMN needle right now.
can YOU sell me all this stuff?
yes,but unless you want to end up with doubles you need to see what you have currently.
got it out and rode it quite a bit today and it runs great....only problem is when its cold its really hard to start. It has the following jetting:
160 main
200 main air
emn needle on 3rd clip
42 pilot
pilot air removed
???? turns out
Follow Eddie's jetting advice and it should be sweet....:thumbsup:
You will need to change out the needle, pilot and Mj..
An R&D Flex jet fuel screw will make adjustments easier..
Check this to fine tune your pilot circuit..http://www.thumpertalk.com/forum/showthread.php?t=327405
