Headlight Bulb Replacement
Need to replace the headlight bulb on my 2006 WR250F. Looks like a relatively standard bulb? Can you get them at an auto parts store?
Also, any "tricks" on getting it out? I don't want to break anything. The bulb won't slip out of the harness connector easily. Are there "detents" that need to be released?
Got the bulb out. The reason it was difficult to get out appeared to be because the end of the plastic connector had "melted" to the back of the bulb plate. Is this a common problem? Just gets too hot?
Found the bulb at a local auto parts store for $10
