Buying a cylinder to fit 90 cr 250
I tried fitting my 87 cylinder to my 90 and I think it won't work. It was acting like headgasket wouldn't seal and probably because of this extra port hole for coolant. Could I get a second opinion? See the rub inside there? A light hone won't take off fingernail size gouges right on nikasil?
I need the one on the right. I'll pay 50 or more depending on bore condition. Has to be usable at least.
www.servicehonda.com
use the advanced parts lookup. Pick out the model, the year and then the part. Click the WHERE USED button and it will tell you the compatible years/makes/models that use the same OEM part. Check the cylinder and the base gaskets.
