Help!! blaster wont rev!!!
Yamaha
My 03 blaster has a problem. It runs and starts fine at idle but it wont rev it just bogs but it doesnt shut off, cleaned the carb well. whats the problem?
Edited by YamahaRider33
needed
Make sure the choke is not on
reeds air filter clean the carb thats what its on the line of intake if it just bogs u could have a pice of dirt ni the seat restricting fule flow the reeds could b sticking if u mix ur gas to ritch air filter could be dirty restricting air flow not anough air to the amount of gas thats a bog thats what ide chek
well i done all that.. im thikin its the reeds
have u been in mud check exhaust to see if its restricted
Also be sure emergency brake is returning all the way in perch 03 and up came with throttle override
possible carb rebuild.
