Does the FCR bowl have a check valve in it?
I have an older style slant FCR off of a DRZ.
It has been nothing but trouble and I can't get it to run down low at all. It won't run off choke so I think the pilot circuit is plugged even though I have cleaned it 3 times
But that's not the problem. The AP pump seems to work only some of the time. New diaphragm in it but it seems that fuel isn't flowing from the float bowl to the AP bowl.
If I take the float bowl off and fill it with water, it doesn't dribble down into the AP bowl. Should it? is there a little check valve in the bottom port of the float bowl that leads to the AP bowl?
Edited by apgamer
Yes it does, behind the brass plug. It requires a vacuum to work.
More than likely, the passage way to the pump nozzle is clogged. Very tough to clean out. You should send the carb in to tokyo mods for a real cleaning.
  • Similar Content
    • By SNORE125
      Anyone else have 130 main and 38 pilot jets already in the carb I took the wifes ttr 230 carb apart to add the bigger jets and this bike from 05 that I bought new already had them in it? I was reading that they came with a 125 main and a 36 pilot.
    • By Charles Joseph Miron
      Hello all.  Need a helping hand here..
      I bought an older TT225 and am not about to spend almost $600 on a new carburetor for it. So I'm hoping someone can help me out with an idea of what (other than original carburetor) style, type and brand I should go with..  I'm also having a bit of trouble finding info on this bike.  It's a 1986 Yamaha TT225.
      Thank you in advanced
      Charles
    • By Br0ck
      Hey guys, I went on vacation all summer and let my bike sit (2002 CR250). When I got back I ripped it apart and cleaned carburetor and put it back together and it started fine and ran alright, but idled really high. I adjusted the idle screw and realized it was a ridiculous amount of turns out. I can't remember exactly how many but id say 6+ turns out. My killswitch was a POS and didn't work anymore so I replaced it with an oem replacement. My last ride I crashed the bike pretty bad and I was off the bike for 2 weeks. I can't get the bike to start ever since I got installed the new killswitch. I think I wired it right I just replaced one wire at a time and it looked pretty straight forward. I verified it by testing spark while holding it in I was getting no spark but with it in running position it would spark.
      Anyway I am just looking for some base settings for the Mikuni TMX to get my bike running again, my carburetor has a 35 Pilot and 380 Main jet which appear to be stock. I am located in Edmonton, AB, Canada which is about 2500ft and usually ride between 10-25 celcius.
      Thanks for any replies.
    • By Goon Rides
      Hey guys... so I have a problem... I took the bike at Cal City, broke it in, and while I was doing so, the bike was bogging in first gear (Yes, first gear). Also it doesn't idle at all. I have to keep blipping it otherwise it'll stall. So I adjusted the screw circled in image 1. Well I was listening to the sound of the of the bike, yet the rpm's weren't increasing, and it was still stalling. So then, I unscrewed the screw in image 2, well I found out that it was fully twisted to the right. So then, I twisted it to the left, still nothing; it was still stalling... where's the idle screw? I am sure that the screw in image 1 is for the air/fuel mixture screw, and the screw in image 2 is the idle screw, just broken? I don't know, any and every help would be appreciated.
    • By Zach7018
      So Ive decided its time to pull apart my favorite machine and freshen it up, and I'm looking to make some improvements in the process. I already have a 3x3 mod and a JD jet kit done and it seemed to have changed the world. The stock bike just plain sucked and now its a lot better. I never expect 450 race bike power here but I know there is a little more and I'm wondering if the juice is worth the squeeze. I already plan to add a header and exhaust, an FCR39 carb and stage 1 hotcams. After some research it really seems like those places are where the gains actually come from, so would it be worth it to throw a 434 big bore kit at this bike or just stick with what I already mentioned and a new stock bore top end??? Also my rides are often solo and pretty isolated,how much of a reliability headache can I expect with these mods?
