shaving rockes
if you shaved .010 .015 off of the bottom of the rocker box would it increse lift of cam, or just f*** up your engine?
It would have no effect on the amount of lift and it would definitely ruin the top end of the motor.
If you did this, after it was assembled the cam would not turn. You wouldn't even be able to start the motor.
thanks, i was not even thinking about the bearing serfaces, that wolud for shure f*** up the engine.
