1996 cr 250 cylinder
Can anyone tell me if a 1996 CR250 cylinder is Nicasil coated from stock?
yes. basicly ALL cylinders are coated from the factory.
and i would NOT sleev it with a metal one. you will hate life and ruin a 96 250 motor with doing so.
i was just wondering because some piston companies give multiple sizes for stock eg.
66.34mm, 66.35mm, 66.36mm, and 66.37mm and others just have 66.4mm as stock size so i am wondering which one to order or does it not make a difference?
deffinitly makes a diffrence. you have to messure your bore and get the right piston for the size of your cylinder bore.
Thx chopper i took my cylinder into work and measured it looks like i need a 66.34 piston for it.
