any valve mods for a ktm 08 530 forks
My 08 530 exc which i resprung for my weight doesnt seem to have the same plushness as my 09 300 exc again sprung for my weight, did ktm make internal changes between years and is there a general mod that people are doing with their 08 models... and just to clear both bikes are oc type
thanks
they altered the tubes on the cc forks to make them flex more in 09, but i dont know on the oc forks, ktm valving will be very different, the valving will be very different IMO.
according to the parts manual the valve stacks says see settings list. where oh where are such lists
wp send out pdf files of stacks to tuners, not to the general public. The suspension world is very secretitive.
Here's the stock valving:
Base
24 x 0.1 (4)
18 x 0.1
24 x 0.1 (10)
22 x 0.1
22 x 0.1
20 x 0.1
18 x 0.1
16 x 0.1
14 x 0.1
12 x 0.1
9.5 x 0.3
18 x 0.25
Mid
24 x 0.1 (4)
22 x 0.1
20 x 0.1
Spring
11 x 0.20 (6)
Float = 0.70mm
Rebound
Delta x 0.1 (4)
12 x 0.1
20 x 0.1
18 x 0.1
16 x 0.1
8.5 x 0.3
8.5 x 0.3
16 x 0.25
The 09 forks changed cartridge diameter so the are much nicer the 08 which really suck.
Here's some stuff I did the might help:
lower oil level down to the 140-130 range
change oil to 2.5wt
revalve to remove 8 24.1 shims from base valve.
I will also soon be swapping out fork seals to SKF and Kyb bushing to help remove the excessive stiction.
thanks cactus ,thats what i was looking for. I might do those mods one at a time and see the difference . 5wt with lower oil hieght. 2.5 wt next. then shim removal.
its not that expensive to upgrade to the 09 internals, bluerider may still have the part # no list I sent him, if not i'll dig it up in the morning
happened to come across 08/09/10 4860mxma oc lists I will probably go straight to 10 specs. big difference between 08 and other years
to upgrade you need:
(this is from ktmtalk pretty sure its right for one leg)
57 ADAPTER SLEEVE D23/D28
48600764 (lower adaptor 20-24mm)
58 PIPE D23/L350 09
48600763 (cartridge)
42 SCREW SLEEVE M27X0,8
48600830S (bottoming cone)
45 PISTON ROD REBOUND
48600576 (MV tap)
47 SHUTTLE VALVE SPRING C=0,4
48600382 (Mv spring)
51 PISTON RING 5X1X68
48600455
52 PISTON REBOUND SX 2007
48600575
+ shims KYB bushings and SKF seals.
That's about $375 US worth of parts for a set of forks. You might be better off just sending them out to get revalved by a pro shop.
the upgrade to the smaller cart diam nets better results than a "pro tuner" can coax from the 08 stuff, just MHO
hey bush , looking at the setting list would you think that just to change the comp stack and leave the 08 rebound stack i would get good results
