new carb or rejet the stock????
i just finished breaking in my new drz sm. i am going to do the 3x3 and get a full pipe, not going to do much more. will a new carb be better then rejetting if all i am going to do is the 3x3 and full pipe??? i dont want to get a new carb if its not going to help much more then just rejetting the stock carb.
People have reported that by changing the carb alone (no pipe) you see more power gains than a rejetted stock carb with full exhaust
Re jetting the stock CV carb will be a marginal performance improvement..It's more about getting the bike running correctly..
However, It dosen't matter how quickly you turn the throttle ,you still be relying on vacuum/air movement to lift the slide..
The FCR is a significant improvement over the stock cab, especially in throttle response..Here your right wrist in controls the slide...
Most that have upgraded to the Fcrmx wished they had done it long before......:thumbsup:
3x3, Fcrmx and Free Flowing pipe is the way to go....SSW/MRD or Yoshi Ti have been proven to be the best in the flow dept....
Edited by CraigoDRZ400sm
just go straight for the fcr......its no contest....makes your drz a different bike
simples
thanks for the help, and fast reply.you guys have made me sure, im getting the new carb. in a few hours im going down to the shop and ordering a full pipe and carb.
lt is well documented that the best two pipes for the DRZ are either the SSW/MRD or the Yosh Trc Ti. The RS2 and RS3 don't make a huge difference... but obviously look better than stock.
Apparently Yosh has stopped making the Trc Ti although it is still available. lt is also an $800 pipe. The MRD pipe is about $550. The Yosh is lighter but the MRD is stronger. Both pipes are very loud... but you cannot achieve power without noise. This has also been well documented.
Run a search here on both products. This forum is heavily biased towards the MRD pipe however there is good reason. lt is a very well made pipe with excellent back up from the manufacturer. lf you do go with the MRD l highly recommend buying the quiet insert.
get the mrd....again theres no contest.....made to develop more bhp than a yosh as far as im aware and developed by eddie sinseros whos the king of drz tuning...sayas it all......whats going to be better ?? seriously??
mrd are top for the drz........
Here's a different take on the FCR, yes it does transform the bike, more power quicker throttle response, at the cost of fuel economy. Yeah others might mention that it's due to the generous amounts of right wrist action. Even when ridding easy I only got 42 mpg, at about 55 mph. Not worth it to me. Fcr is nice for power but the stock carb and 3x3 with a Dyna Jet is good enough for me. Just depends on what you want.
you need to get your facts straight.this is wrong.
the yosh trc pro ti and the mrd/ssw systems make the same power and differ only in their delivery.the yosh is still the lightest pipe of them all but fragile.but after running one for 5 years i haven't had any issues.
+2 on the Bum!
To the OP, get a FCR from Eddie, do not bother going anywhere else.
If you have money, get the Yosh Ti. If you want to save a little and perhaps buy me a present for my sage advice, then get the SSW/MRD pipe. The Yosh is significantly lighter, light costs.
MRD customer service is top notch. Yosh, well it depends who you are. I personally have outstanding service from them. Others report being snubbed.
bumtarder
eddie said this recently when explaining about the mrd ssw
#13 05-01-2011, 02:19 PM
Eddie Sisneros
TT Intake Expert
Quote:
Originally Posted by MoBeffah
Yes please clarify cause I have an rs3 and was under the impression even the rs2 is better.
no, the rs2 and rs3 are basically the same. AVERAGE off the shelf pipes.
For price quotes and info pertaining to sales and service email SSpeedWorks@gmail.com,call 303-485-1858 or for quick and easy purchase SisnerosSpeedWorks.com
CLICK HERE for official Sisneros Speed Works team T-Shirts
  • Similar Content
    • By Bignerd0100100
      Hey all,
      I'm looking at buying a 2004 Suzuki DRZ400EK or at least I think it's an EK according to Vin lookup websites, but it does not appear to have a kickstarter. I was told the bike was owned by a motorcycle dealer and that it has a current green sticker, and a California license plate but has not been registered for the streets since 2011. I want this as a dual sport but am not clear if the fact that it already has a plate means I am good to register it or if maybe they took away the ability to register it after it was plated, California loves to do that kind of stuff. Since the bike was owned by a dealer I would think they were up on the latest regulations in California, but who knows. Can anyone add any insight as to what I should look for on the bike itself like the carburetor, model numbers etc? Or do I just try my luck at the DMV?
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
