Water trail out of the water pump weep hole
2010 400xcw anyone know what seal needs to be replaced and if the side cover needs to come off. Thanks
It's most likely the o-rings on the round seal carrier. The Thumper Racing kit has everything you'll need. A pair of snap ring pliers will come in handy to remove the impeller and the seal carrier. I used dielectric grease on the o-rings since they don't swell or decay rubber. Make sure you smooth out the impeller shaft with a Scotchbrite pad before sliding the new seals on lest you cut them up. Look for the video on YouTube by mcgoodies; shouldn't take more than 30 minutes to finish.
I cant tell you for sure but Thumper racing sells some seal kits and has a video showing how to do it
I didnt see anything on Thumper racing for the XC4 motor
I have an 09 400xcw and have replaced the oil/water seal twice in past 2yrs.
It takes about a half hour to replace the seals and with your bike being so new, the gaskets around clutch and inner primary can be re-used.
On my bike, I am suspecting that there is a groove or imperfection on my impeller shaft so I am replacing it soon before the hot weather sets in.
