Turbine core 2
My god has anyone ever fully broken this silencer down? I just got mine apart and this is the biggest mess I have ever seen in my life. There is so much spooge and sloppy packing I had to take a break from it. I'll probably get some mineral spirits and just soak the rest of it in the that. If anyone has broken theirs down post here and let me know what you discovered haha. Cheers!
turbine cores usually break themselves down;) both turbine cores i've had experience with have rattled them selves too pieces and lost all the rivets.
I took mine all apart a couple of times. Just take that inner core and throw it on a propane fish cooker burner. It will burn all that stuff off clean as a whistle.
Just use brake cleaner to clean the inside of the can and the tip. Don't use heat on that, it will cook off your stickers! They really should make that thing easier to get apart. Spooge builds up in the tip really bad.
