different jet types and float needle?
bit of a noob question but i want to try some different jets in my kx250. If it has the hexagonal bolt type fitted can you use the flat head screw type?
also when you replace the float needle do you need to fit a new seat?
No, you use the same style it current uses.
Ususllay, when you buy a new float needle, it comes with anew seat. So I swap them as a pair.
