CRF230F Re-Discovered
I Haven't posted on this CRF230F threads for a while as I decided to get rid of my plated 03 CRF230F after picking up a new Husqvarna TE310. However the economy being what it is my 230 hasn't sold so the good news for me is I took it off the consignment lot and now its a keeper.
I'll probably get back to complete the engine modding but in the interim I need a quick fix for the front forks. My spring sag is fine with a single BBR. However my stock valving sucks as I run through travel and bottom out even on modest jumps. Back shock is a Works so no issues there.
My question: For those who have played with fork oil as an interim solution, what weight fork oil have you all used successfully to help minimize the front bottoming on modest "say 4-foot high" jumps (190lb rider)?
I think your best bet would be to add racetech emulators and 15wt fork oil. That combination seems to work really well for most. Check out the racetech database thread for more details.
Per BikeBandit.com:
"Race Tech Gold Valve Emulators are tunable valves that sit on top of the damping rods & are held in place with the main springs. They make damping rod forks perform like well-tuned cartridge forks. Simple to install & completely tunable for all conditions & rider preferences".
They run about $150 but make a huge difference and are well worth the $.
Yep that's the plan. But I was just trying to work out a stop gap measure in the interim. I have another bike (DR650) that also needs a pair emulators and it also needs one of their new complete adjustable rear shock internals. Racetech will soon be breaking my piggy bank but hell its worth it.
I may go ahead and get the emulators for the 230 first since its getting abused at the local mud pit a bit more lately.
Update: Dumped out the old oil not sure what that was. It didn't have much in there not even close to the OEM specs. Filled it with 15w 380cc in each fork. Can't tell much by bouncing it around the yard so for now it will have wait until I can get to the local mud pit and hit some jumps this weekend.
Edited by T30
The way you're filling it up, pre measuring 385cc, and pouring it into the fork is a method used for the twin chamber forks. you might want to search on here for detailed instructions for 230f forks, which is an open chamber. To fill up open cartridge forks w/ oil , you measure the fork's air chamber with fork compressed,spring taken out.
Yep that's what I did. Forks compressed springs removed. It seems to be OK riding and bouncing it around the woods around my house, but I'll get a better feel for it Saturday. I'm going out to a riding park hit the jumps that bottomed it out last week.
those forks are very similar to the 79 and 80 cr forks we used to run the oil 5 or 6 inches from the top springs out if you are bottoming add a little more oil gradually say start at 6in the go up from there, the theory was that the more oil the less air so the air actually becomes part of the spring action,
Did you notice much difference when you changed the weight of the oil?
Well the 15wt oil and probebly also adding the OE recommended amount made a big difference. I'm not bottoming out the forks anymore and as a consequance. I'm even hitting the jumps a bit higher now on the CRF230F. I'm rethinking the need for emulators.......but i'm sure I won't be able to resist the temptation,
  • Similar Content
    • By hondahondo
      A few picks of my winter project.
    • By Australian Psycho
      So I want to fit a Speedo to my stock Honda CRF230F, I know people have fitted the Trail Tech endurance to them but they are a bit pricey so my questions are is there another reliable Speedo or is my best choice to bite the bullet and get the Endurance? My other question is the stock stator for the CRF230F enough to power a Speedo or more specifically a trail tech endurance 2? I fully capable of installing it and splicing the wiring, my question is just can the stock bike support it? Also the Bike does not have a headlight.
    • By StreamZ
      I am in the process of slowly repairing everything on my 230 that had been bought from a farmer and obviously had no love ever in its life. Anyway, as I pull off one thing, fix it, reinstall it and then ride around again, I keep coming back to it not being the most aesthetically pleasing 230 on the planet. I was wondering if anyone has suggestions for sticker kits leave 'em below.
      FYI: I would like to keep it as stock looking as possible maybe even use the sticker kits from the last couple years of motorbike.
    • By Daniel627
      I hate finding awesome deals, but not able to make it happen!
      I found a complete '05 crf150f that I would love to get for the gf and get running. He wants $400 obo. It's a 7 hour drive though. I would have no problem making the drive normally, but even if he'd take $300-350, it would still cost me about $150 in gas. I can't really justify spending the money at this point in time and that sucks balls!
      I just had to rant for a moment
    • By Dumpdaveinfl
      Hey guys,
      Just  finished my xr and wanted to share some pictures with what I done. I have read a lot of posts on suspension for the xr, so I’ll share my mods.I got a set of dnm hornet forks from my wife on my birthday. With a new front I had to do a conversion on the back-so I went with a Crf150f swing arm that got off eBay. After some machine work in a Bridgeport mill removing 5/8 off each side it fit. I removed extra 1/4 inch to allow for chain alignment so it could be shimmed. The  frame was over drilled to 14mm and had to shorten the bolt by removing the bolt head and re-weld a nut to the stud. The shock is temporary until I figure linkage or direct mount but for now it’s a 11 inch fast ace 1100 lbs with adjustable rebound. Also for ease of service I drilled and taped the swinger and shock pivots with 6mm zerks. The wheels are the stock Crf150f and installed Ebc slotted brake pads.
      The DNM front forks were a challenge as no bearing combination would work with the 41mm race. I used a set of roller taper stock bearings and shimmed the bearing to the triple stem. Brake caliper had to be modified with a new bracket to use the 240 rotor. Also I have yet to find information to support these forks so if anyone has information on these please let me know..
      35inch seat height
      as for the rest of the build the motor has a engines only 120 kit with cam and slotted cam sprocket and mikuni tm24 carb. Shower head and oil pump by Daytona and alto red eagle clutch with bbr springs and a hydraulic clutch. Cdi and coil, new seals. installed a bbr  cradle with engines only aluminum front mounts. Had to remove 2mm off the engine and frame dowels to get these to work together. A new seat cover and foam with a clean up on the plastic. Let me know what you think. Thanks
