changing bars should i do anything?
I bent my bars pretty bad last year(over an inch back and down a bit) and am getting the bike really ready for this year so besides doing the teflon tape under the lever perches what else should i do? do i need to adjust the clamps in any way? could i put teflon tape under the throttle tube to make it smother? anything that i should look for damage wise?
I would definitely NOT put teflon tape under the throttle tube. It would eventually tear and wad up and make twisting the throttle very difficult, if u have and aluminum tube a little grease is ok but for a standard plastic tube I wouldn't put anything under it.
Check all the places that it mounts to where there can be pressure points and such. Look for stress cracks or tares. Also I would check your levers for the perch to be bent possibly.
I put copper anti-sieze on all of the bolts. My son didn't and broke one of the top clamp bolts.:thumbsup:
