Just bought a full exhaust, do I "have" to rejet??
Just bought a full Leo Vince X3 system, I know absolutely nothing about carbs and jet kits, am I going to have to rejet the bike? Will it run like shit with the factory setup?
Thanks for any help. I tried to search but there are literally thousands of threads to go through.
Yes you do.
if you dont rejet it will run like crap,,
your 2 options are dynojet kit #3110 ($55)or James dean kit #jds005($75),
Both kits will do the job, most people get the James Dean because of the replacement float bowl screws and extra pilot jet that you wont need if you buy the keitech ext fuel screw($14) however it is more expensive. DYnojet kit comes with a screw and drill bit for fuels crew plug access,no float bowl screws, which arent really needed, but recomended. Float bowl screws can be bought seperatly for $5. Eithr kit you will have extra parts. All complete instructions are provided,its easy and heres a video for reference..
That should be all the info you'll need..also read some of the jetting threads..
ok thanks for your reply, I just watched that video so I went ahead and ordered the JD kit
http://www.jdjetting.com/xcart/product.php?productid=53&cat=1&page=1
do I need anything else??
get the ext fuel screw, makes things easier
I knew I should have waited before placing the order :thumbsup:
Do I need the fuel screw or it just makes things easier??
you dont need it it just makes it easier to adjust because it hangs out the bottom making it easy to turn. hence 'extended' fuel screw
you don't need it,but it makes adjustments easy thestock screw is very hard to get if you need to adjust it, ifyou ordered from tt store just call them they'll add it to your order.
ok thanks. Sorry for my ignorance, I just know absolutely nothing about this.
I ordered it from directly from JD, maybe they'll be able to add it to my order as well
if they carry it..make sure you get keintech
yupper
yupper
ok cool thanks so much for your help man
ha its all good i didint know before i got mine either!!! good luck.
You should do the 3x3 mod while your at it too.
Jetting with Leo Vince/3x3/K&N
155 main jet
blue needle
clip 4
25 pilot jet with the stock fuel screw
22.5 pilot jet with the extended screw
2.75 turns
Alright guys just did the 3x3 mod, took out my carb, and took of my stock exhaust. Going to pick up my Leo Vince tomorrow and my jet kit should be here by thursday.
Ill let you guys know how it goes. Wish me luck....
