2008 wr250f float bowl removal
You'll need to rotate it. Only takes a few minutes:
Remove Seat
Remove Gas Tank
Remove Motor Mounts
Get some slack on the cable down to the carb area (you may want to remove hotstart from carb)
Loosen boot clamps on either side of carb
Rotate bottom toward shifter side
Plenty of room to pull the float bowl
If.... you are unsure of yourself, you may be better off removing the carb. It is easy to damage the float, loose the pin or other issue if you are not experienced.
